K
Is there a relationship between no of rows of VSV and the engine RPM? For example, gas turbine MS-5001 has 5089 rpm with only one row of IGV while PGT-10/2 has 10000 rpm with 5 row of VSV. Any one has a clarification?
Please I need somes documents of LM 2500Speed is basically a function of the design of the axial compressor. GE-design Frame 5 heavy duty gas turbines were designed decades ago, before VSVs were considered for use on heavy duty gas turbines. And, a GE-design Frame 5 is physically much larger than a PGT-10/2, and trying to control speed and vibration on even a Frame 5-size machine when it was being designed (probably mostly with slide rules) was difficult if not impossible.
If I'm not mistaken, a PGT-10/2 is based on a much more recent aircraft engine design and construction methods, with lighter materials.
Finally, it's my understanding that VSVs are primarily used to, one, be able to increase the mass flow-rate of air through the axial compressor, and, two, when possible, to make the axial compressor smaller (shorter) and decrease the size (physical mass) of the axial compressor rotor.
by Bob Odhiambo
by Bob Odhiambo
