Once the power is removed the integral electronics can't apply any signal to the proportional magnet.Good day, Can i change the Fail safe for Moog D638..
I use the Moog Software to calibrate the Zero and Span..
But the issues now is if you remove the Power the failsafe is suppose to close the valve slowly, But instead it opens the valve to maximum Open.
| Thread starter | Similar threads | Forum | Replies | Date |
| R | MOOG Servo Valve 761 X Port | Control Valves | 3 | |
| F | Moog Servo G772K240A | General Automation Chat | 1 | |
| T | Servo valve Moog installation | Power Generation | 6 | |
| A | Moog Servo Valve | Control Valves | 2 | |
| J | 760 Moog valve mounting to hydraulic cylinder | Control Valves | 0 |
