Good morningAre the generator temperature RTDs connected to the VRTD (via the TRTD)?
How close to the generator are the lightning strikes?
If the turbine control system is a Mark* VI then the unit is probably about 20 years old, plus or minus a couple/three years. What has been happening before this last year when lightning strikes occurred? Same behavior? (And, as ControlsGuy25 has noted, we need to know how the VRTD card or the RTDs connected to it are reacting when a lightning strike?)
Do you know if the Mark* VI has both a functional earth and an instrument earth? If it does, have you checked the potential between the two earths recently?
