Hello, I have problems with a markV Simplex, HMI with sonftaware GCI and cimpliciti 9.0.
#1- The problem occurs when I do logical forces. The forces that I do on input points on CD work Ok, if I look at the prevote data it is seen that the point is forced on both R and C processors and the Mark F appears above the forced point in the rung
But when I do the same at a point in QD it only changes state in R, in C it remains with its original state, and it does not show me the F mark indicating that it is forced. It is difficult because if in a test I do not write which signals I force, to be sure that there are none, I must restart the Mark V
Any idea what it could be?
#2- diagnostic alarm
It repeatedly throws me diagnostic alarms
TCE1 power supply out of limits dcom
TCE2 power supply out of limits dcom
TCE3 power supply out of limits dcom
What should I check to solve the problem?
I have many more alarms but I don't want to bother you, it is a machine abandoned for more than 10 years and it is in the recovery process
