Good day
I have a generator that has an intermittent fault, which it looses load(kW) nearly instantly then go reverse load(kW), the PMS detects this issue then disconnects the generator from the bus. I have included trends from 3 generators that where paralleled at the time of fault. The fault is happening every couple of months. From what I can see is the generator 2 loses all load but only half its current. We can see the the exciter current increases on all 3 generators at time of fault.
Need to know where to look
1. AVR issue
2. Diode issue
3. Other issue
1. AVR issue
2. Diode issue
3. Other issue
