We have a GE 9E gas turbine on site, and the control system uses a GE Mark V HMI. Right now, we’re having an issue with the GCV (Gas Control Valve), and we need to replace it. After replacing the GCV, we need to calibrate the LVDTs (Linear Variable Differential Transformers). Once the automatic calibration is done, the system will generate the zero-position LVDT voltage and full-stroke LVDT voltage.
Normally, we would take these voltage values and enter them into the I/O Configurator, then download the settings to the R/S/T controllers, and finally power them off and restart them. However, we’re concerned that restarting the controllers might cause problems, as we’ve had issues before where the controllers failed to restart properly after downloading.
So, our question is: after the automatic LVDT calibration is complete, can we skip the download and controller restart, and just start the turbine directly? Since the calibration already writes the LVDT voltage values into RAM, the values are already active and being used.
Can we delay the download and controller restart until the next planned shutdown, when a GE engineer is on site to help? They have more experience with this process and can assist if any issues come up.
