Hello everyone,
I would like to log 5 thermocouple values in real time, with a 2-second interval, repeated 10 times.
The logging should start on a rising edge (HMI button). After 10 samples, the data should be saved to a CSV file, and then the array should be reset for the next acquisition.
I’ve heard it’s better to use a cyclic interrupt OB (e.g. OB31) instead of timers in OB1 or TON.
So in short:
My question: What is the simplest way to implement this in TIA Portal (SCL or Ladder)?
Has anyone already built a similar program and could share an example or some guidance?
Thanks a lot!
So in short:
- Rising edge → start logging
- Every 2 s → capture 5 values → write to an array
- After 10 samples → stop, save to file, reset array
Thanks a lot!
