P
We are using controller AC450 in our system. On MB300 three controller have been connected. The length is around 350 meters. Two controllers (A & B) are very near to one end while the third one (C) is at the other end. The system was running very nice but for last few days the communication between PLC which is at one end with other has become very slow.
The two PLCs which are near to each other at one end are communicating very nicely, but the communication with other PLC is nearly zero.
When I connect the programmer at PLC (A) I can see PLC (B) and vice versa, but not (C).
When I connect programmer at (C), I am not able to see PLCs (A) & (B).
The end resistor at both ends are ok 50Ohms. Also at each transceiver resistance is ok. By opening end resistor at one end and checking from other is also ok, that means cable is also ok.
Any suggestion...
Any suggestion...
