OK, I will try to work on this point and get back.I mean try to find out if encoder is sending good signal to drive module..
That can be a point to look for..
I can't give a comment if that is because of load/roller...I have observed that the motor is working fine without load.
Does it means that the problem is with roller set?
If so, then why does the motor run without problem, occasionally?
Or the problem is due to load inertia or some other technical parameter? Due to lack of experience, I am not sure.
OK, but can you guide me to aspects on which I should work on.... like Load Inertia etc.?I can't give a comment if that is because of load/roller...
My suggestion /advise was to check first if encoder is working properly..
