G
We have a Frame VI GE Gas turbine duel fuel on NG and HSD. Recently we are facing problems on one of our machine, in which atomizing air temperature quickly drops to around 60 degC from 105 degC and pressure starts hunting between 12 to 15kg/cm2 whenever fuel is transferred to HSD or NG/HSD mix. Precooler flow regulating valve is robertshaw make which we operate manually to adjust AA temperature, but when this valve just slightly opened/closed there is an unusually huge drop/rise in AA temperature, say for eg: 20degC drop. We checked the check valve parallel to booster compressor to see if the air flow in circuit is restricted because of it but the check valve was found working fine. Another interesting observation is that the discharge temperature of main AA compressor was measured using a temperature gun and found to be around 170degC, about 30degC higher than on our other machines.
