Hi everyone
am trying to establish Modbus RTU communication between siemens CM1241 (485/422) module and delta VFD M-Serie (with Rj-11), the picture shows how i did the connection, but it does not works, so i switched (3 to 3 and 4 to 8) and for the CM1241 GND i used pin 1 and pin 5 ,so with all it does not work
both plc and vfd uses the same GND
where is the problem !!!
