Communication protocol converter(Getaway) selection problem
Hello all,
I need help for selection communication protocol converter.
Scada system supports Ethernet IP protocol and I need to communicate with profibus slave device.
I think I choose HD67643-A1 ADF Web EtherNet/IP Master / PROFIBUS Slave - Converter.
But some of my friends told me I need to choose HD67593-A1 ADFR Web EtherNet/IP / PROFIBUS Master - Converter.
I suppose that your scada has an Ethernet/IP master which can communicate with an ethernet/IP slave on the HD67593-A1 gateway. The other side of the gateway, profibus master, can communicate with your profibus field slave device. So I will choose HD67593-A1.
Best regards,
apa
Best regards,
apa
You are absolutely right. Correct one is HD67593-A1. We solved that with some pain.
