When initially pulling vacuum on the condenser, some people insist:
Start the vacuum pump first, then open the isolation valve between the pump to the condenser, others the reverse order of operation.
Was reviewing logic for a combined cycle plant in Europe and saw that the logic first openened the isolation valve between the vacuum pump and the condenser and then started the vacuum pump.
Checked with another plant in England and they assure me it is always done this way.
This is different than my experience with coal fired utility plants in North America, where the logic will typically ensure that the isolation valve is closed, then start the vacuum pump, then open the isolation valve.
Am looking for:
a) others experience about typical operation.
b) reasoning which is used to motivate each choice of operation.
Thanks,
Bob.
Am looking for:
Thanks,
Bob.
