I am looking for a way to control a normally opened contact via email.
Let me explain:
On board my yacht, I have several racks with IT equipment and each rack has a temperature monitoring device Room Alert 3E installed in it.
Each Room Alert 3E is connected via Ethernet to one of the network switches and I have a nice little interface where I can monitor the status and temperature of each Room Alert device.
Now, if the temperature set point is reached, an alarm in the Alarm systm must occur.
We have an Alarm system onboard and we must connect all the Room Alert devices to the Alarm system somehow.
We don't need to have specific alarm for each Room Alert device, we can have common alarm when any of the device is triggered and then I can check where exactly is the problem.
Pls note that wiring each device to our Alarm system is not an option.
My idea is following:
1. Room Alert devices can send a mail to a certain mail address when the temperature set point is reached.
2. With the help of some magic hardware, this mail triggers the normally opened contact on this hardware.
3. When normally opened contact is closed, the Alarm system will be activated.
Sounds complicated but if you look at the attached file, I am sure you will understand it.
I think I will be able to figure out how to get Room Alert devices to send mails to a certain address.
And getting Alarm system to get activated is easy, it's only a matter of closing a NO contact.
What I don't know is - is there a device that can receive a mail and, upon mail receival, trigger a NO contact.
So, this magic device would have Ethernet (or even wireless connection) on the input and NO contact on the output.
Pls let me know if I need to explain something better. Thank you!
Let me explain:
