R
We want to connect a terminal (sample of a cellular phone emulator) with a PC via Ethernet.
The terminal can do 100Mbps interface and the PC-LAN-card can do 10 Mpbs.
In between we install the NetGear hub we got delivered from the terminal manufacturer.
Connection works fine.
When we replace this hub by a switch from NetGear or "get...Net" (brand name) the terminal reports via a serial monitoring interface always "No Carrier".
Both, hub and switches can cope with 10 and 100 Mbps on each port.
As far as I have learned a switch does the same job as a hub plus it´s switching specific qualities.
So then why this NoCarrier problem when we use a switch ?
Perhaps someone has already encountered the same problem and found an explanation ...
|uplink
terminal <-----Hub or Switch----->
Best Regards
Rainer Haseneder
from sunny Germany
|uplink
Best Regards
Rainer Haseneder
from sunny Germany
