Hi, I'm a system integrator involved on a project for a big water plant. In the computer room we need to connect four Windows NT4.0 SP4 WORK
STATION with a redundant fast ethernet network.
To do that we think to use the "Intel=AE PRO/100+ Dual Port Server Adapter" on each computer.
Each computer is connected to two HUBs (Adapter configured in fault tolerance mode). If a HUB or a cable fail the "Intel=AE PRO/100+ Dual Port Server Adapter" will swap to other port and connect the work stations by other HUB. Has anyone experience with fault tolerant network configuration ? Is this configuration working with Windows NT SP4 WORK STATION ?
Please let me known if this configuration will be working.
Thanks in advance.
Thanks in advance.
