Hello ! With what software could I put the program in this plc and what adapter would I need to connect?It is very old and I can't find anything about it. Thank you !
Hello Radu,
I don't have any direct knowledge, I just found the information that I shared on the internet.
You can find the CL200 manual, which says that the X31 Interface is used for programming; and "A premanufactured connecting cable is available to connect to the X31 interface connector: K16 Connecting cable, 5 m Order No. 1070 054 956".
You can also find the CL200 Operations List Software Manual which describes programming with the “PROFI” and “WinSPS” software.
I suspect that you will have a hard time finding what you need to do this.
Best of luck!
. Thank you for your time . I will try and I hope I succeedHello Radu,
Best of luck!
