good evenning
when I disconnect an instrument (analog input) from the field which is connected to GEIP9070, a purple hardware alarme appeare in my HMI with SV (software value) indication near the instrument indication and a fault contact being True in the logic, it will not be false enven with clearing fault table
the only sollution i find is stopping PLC and start it again.
if someone can provide an other solution without stopping PLC
thanks
thanks
