Import Data from Monitor Pro 6.6
P
patrick menage
I am using Monitor Pro 6.6 on NT4 on a factory equipment to capture temperatures. In order to share these data, I need to import them to Microsoft SQL Server 7.0 with DTS. I would be grateful if someone could let me know what is the file to read and what is its format.
In advance thank you
Patrick Menage
T
Trajano Roberto
Patrick,
You mean export the data from Monitor Pro to Microsoft SQL Server? If yes, you should use ODBC, the Open DataBase Connectivity driver for Microsoft. Consult the Monitor pro ODBC documentation.
Hope this helps
Trajano Roberto
Sales Engineer
Schneider Electric Australia
