K
We are having ge frame 9e machine- dln.when machine is on base load ttxm is 567 *c is manintained which is being controlled by cpb biased exhaust temp. Control. when machine is on part load ttxm ( exhaust temp )is 600*c ( igv is <60 degree) which is being maintained by igv temp control. when igv reaches <60 deg inlet bleed valve starts opening.
My query is base load is the max temp limit.but during part load exhaust temp is 600*c.
Kindly explain igv temp control philosophy. function of inlet bleed heat system. what is cpb biased exhaust temp.
