This is more of a mechanical measuring issue. We use polyester felt in our manufacturing process that is cut to length. In the past we used mechanical measuring wheels that were expensive and never lasted long. Not to mention they were not very accurate.
We recently installed a bunch of encoder with digital counters for foot measurement and most of them do a great job. Not super accurate but good enough for rough cuts. They are all the same model and all but one machine has repeatable accuracy.
The machine in question is our Slitter that cuts the material into measured widths.
In this case I calibrated the counter using 4mm plastic coated felt. Since this is the first step in our process we set it to be approx' one foot over @ 100 feet. An issue started popping up where the material from this machine was coming up short. They would cut 510 to 520 feet and the next machine would measure it as say around 485 feet.
We checked the counter on the second machine a few times. It's good to go.
On the first machine, the Slitter, we found out that the thicker the material the shorter it would be at the same foot count. This is what caused our short lengths on the second line. This might be an easy issue for some but I am stumped. It would be a major pain to relocate the encoder on the Slitter so here I am trying to get some insight on this.
The encoder is spring loaded against a guide roller on the slitter, top of picture. All other encoder wheels are running on flat material that runs through our production lines. Similar to the second machine in the picture.
Anyone see what I am missing here?
