Hi guys!
I really need some help. I have a device (inverter) with a Modbus rj45 port and want to connect it to a MGate MB3130 Serial to Ethernet Gateway (to convert from Modbus RTU to Modbus TCP) and test the connection with Modbus Poll. The settings of the gateway should be correct (baud: 9600, parity: None, Databit: 8, Stopbit: 1, Flowcontrol: None). The gateway is set to convert RS-485 4-wire to TCP/IP.
I can't figure out, how to connect the rj45 cable to this gateway. How do I have to connect the cables of the rj45 cable to this db9 adapter? You'll find the necessary pictures attached.
Hope somebody can help me
