Multi Serial Port problem. - URGENT !
R
Rick Lee
Dear everyone,
I am a software engineer working on QNX platform. Now I have a problem and need help.
1. I get a PCI-bus Multi Serial port card. This card can provide 8 serial ports.
2. I plug this card in QNX platform.
3. I use the show-pci utility to this card, this utility tell me that this card's IRQ is 10 and the I/O base address is 0xb800, so the I/O base
address for the 8 ports are 0xb800, 0xb808, 0xb810, 0xb818, 0xb820, 0xb828, 0xb830, 0xb838
4. Can I directly use the command "Dev.ser 2f8,3 3f8,4 b800,10 b808,10 b810,10 b818,10 b820,10 b828,10 b830,10 b838,10 &" to map COM1, COM2 and 8
serial ports to /dev/ser1, /dev/ser2, /dev/ser3, /dev/ser4, /dev/ser5, /dev/ser6, /dev/ser7, /dev/ser8, /dev/ser9, /dev/ser10 ?
5. If the answer is not. Does it mean that I have to write a device driver for this multi serial port card ? Can you tell me how to do it ?
6. In this architecture, the /dev/ser3 ~ /dev/ser10 share the same IRQ 10. Does it will affect the data transfer rate and data accuracy ?
Best Regards,
Rick Lee
Armin Steinhoff
Are there addresses assigned to the base address registers ??
No ... I don't believe. It depends on the design of the PCI interface. The register sets of the serial controllers are mostly mapped into memory ... so the driver doesn't use port IO.
I'm afraid ... yes.
Good question ;-) ... Try to get at first a specification of the hardware interface of that board.
No -> if your board has a co-processor -- probably yes -> if your board is a passive one. The capability to buffer the character stream is also important ...
Armin Steinhoff
