Hello CSA,
Thank you for your answer, it is all clear. If I want to manage my gas turbines I have to put one/two in isoch and other in droop speed Kw. The turbine in droop will keep the load, then the others turbines in isoch will change load when increase o decrease. But in my system is not possible setting the load when the turbine is in droop. Then if the turbines in isoch goes to trip, what's happen in the turbine in droop?
The system is in island
