L
We have a frame 6B gas GE gas turbine. recently we have noticed a repeated starting failures due to starting device trip. The starting diesel engine speed is normal 2175rpm but the turbine has tripped at various speeds (35% to 47% tnh).
Sometimes the start attempt has succeeded but the others not. Does this means that the diesel engine is not the cause of trip as it sometimes complete normal sequence and the turbine synchronize? during troubleshooting the problem view2 and viewq functions have been used and they revealed that the jaw clutch limit switch change its signal before the starting device trip.
Does the clutch opens due to loss of torque from diesel engine or from a wrong signal from limit switch?
For a test can we make a logic forcing for the limit switch during start to eliminate the possibility of wrong feedback or its dangerous as there is a possibility of the opening of jaw clutch actually and as the trip signal is forced the jaw clutch would be broken.
Thanks for your quick feedback
