I am an electrician from Suriname, South-America and I am new to PLC's. I installed a new Allen-Bradley slc504 processor on an existing 13 rack system and could connect fine using rslinx2.2 autoconfigure. Because I didn't have a softcopy of the program I downloaded the program from a memory module (1747-m3). The download from the memory module was performed succesfully.
After the download I tried to connect again using the autoconfigure, but this time it failed. It gave this message "Failed to find the Baud and parity! Check all cables and. switch settings”. When I reset the processor to factory setting using the instructions in the processor manual, I managed to connect, still using the autoconfigure option. This slc-504 is used on a Besser Block machine.
Please could you help me with a solution, it would help me a lot in trouble shooting this machine.
Thank you!!
Randy.
Thank you!!
Randy.
