P
We are installing Vcone meter for wet gas metering on wellhead flow lines. I need help from flow metering expert to advise:
1) Is there a pipeline straight run requirement (upstream and downstream) for Vcone meter as per ISO5167? Most vendors specify 3D upstream and 1D downstream.
2) Can I use the DCS algorithm for the wet gas calculations or a dedicated flow computer is required?
3)Is there any specific software requirements for the wet gas calculations?
Thanks for any advice.
