We have a machine with one VFD which feeds a common bus to 10 high speed spindle motors, all operating at the same frequency - this bus is enabled continually, with individual relays operating as dictated by the plc outputs of the machine.
Occasionally this bus goes dead but the VFD reports that there are no errors, therefore the plc does not recognise a fault and the machine continues to operate, however the spindle motors do not spin and we have mechanical breakages as a result.
I would like to fit an indicator of some sort to the common bus to either indicate to the machine operator that all is good to continue, or fit a 'relay' to drop out if this bus goes dead. I could then wire the relay contacts to the VFD healthy circuit.
If you have any advice on this, I would be grateful.
Thank you
Chris
Thank you
Chris
