Hi All,
I am looking for a solution to predict bearing failure for a slow machine (rotation filling machine) used in food industrial.
The application is to put a vibration sensor on a very slow machine to monitor the bearing failure, the problem is technically can we pick bearing failure if the machine is very slow? if there is away can you guide me which sensor in terms of frequency etc. or if there is any documents for slow machine vibration monitor.
Thank you in advance and I am looking forward to hearing from you.
