i want really to ask when a synchronous generator in a big network converts to motor? what are the cases? and what are the reasons? can we proof that using equations?
just a question, In some industrial plant like PTA, in case of there's a failure in the steam (or the reactor) it's required to keep the synch. generator connected to the grid and work as a motor. How this transient/swing condition considered in the electrical equipment/breaker sizing.A synchronous electric machine can be either a motor or a generator depending on the amount of torque being applied to the synchronous machine. If the torque exceeds the amount of power required to keep the synchronous machine spinning at rated frequency when connected to a grid supplying a load (motors, lights, computers, etc.) then the synchronous machine is a generator, converting the excess torque into amps which are being transmitted over wires to motors and the other types of loads (lights, computers, etc.).
When the amount of torque being applied to the synchronous machine is less than amount required to keep the machine spinning at synchronous speed then the synchronous machine becomes a motor, drawing amps from the grid to maintain speed and actually "driving" the prime mover (turbine, reciprocating engine, etc.)--which can be very damaging to the prime mover.
There are very large hydro-electric facilities called "pumped storage" facilities that serve as synchronous generators during the day allowing water to run "down" through the turbine driving the synchronous machine. Then at night, the synchronous machine is used as a motor to drive the turbine which becomes a pump and pumps the water back "up" to a storage lake where it's ready to be used to drive the machine as a generator the next day.
Some large heavy duty gas turbines employ the synchronous generator as a motor during starting and acceleration.
There are many formulae that can be found at sites like wikipedia.org to describe how motors convert amps into torque and how generators convert torque into amps.
by Bob Odhiambo
by Seth Price
by Seth Price
