I have a pressure sensor, which communicates to an RTU via MODBUS. The RTU schedules power to the sensor every 5 minutes for data collection. The data is logged on the RTU and uploaded to the cloud every 2 hours.
I want to be able to visualise the sensor data, so thought I could put in an HMI, though I guess in this case it would be in slave mode? The HMI doesn't really need any other functions (no sensor control required)
Is this a normal use for a HMI, or is there a better alternative?
If it can be done, whereabouts within the array does the HMI sit? Can an RTU output the data to a HMI? Or does the HMI typically sit between the sensor and RTU?
Newbie here, so any assistance much appreciated.
