AI Vision for Faster Inspections & Smarter Production
Discover how AI-powered machine vision is transforming manufacturing by improving inspection speed, accuracy, and scalability. Learn how to choose the right vision solution—from rule-based inspection to Edge AI and Advanced AI—to optimize quality and production efficiency.
In partnership with Cognex
Webinar Overview
This webinar from Cognex shows how AI-powered machine vision closes the gap, enabling faster, more accurate inspection while creating a scalable foundation for automation. It also helps customers understand which vision approach (rule-based, Edge AI, or Advanced AI) is right for their specific applications.
Customer Problems This Webinar Addresses
Simply catching most defects is not enough
Increasing line speeds vs. inspection accuracy tradeoffs
Difficulty detecting subtle, variable, or micro-defects
High cost of escaped defects (recalls, downtime, brand damage)
Over-reliance on manual inspection or rigid rule-based systems
Struggles scaling inspection solutions across multiple lines or facilities
What Viewers Will Learn
How to identify whether their application requires rule-based vision, Edge AI, or Advanced AI
Where AI delivers immediate ROI vs. where traditional vision still works best
What production-ready AI actually requires (edge processing, usability, scalability)
How to reduce inspection complexity while improving throughput and yield
How to scale from a single use case to enterprise-wide deployment
Free Webinar Registration
