Industry White Paper
Machine Monitoring with Edge Devices
Keep equipment running and reduce downtime. Learn how edge devices enable real-time monitoring for both modern and legacy industrial machines.
August 05, 2025 by Opto 22
White Paper Overview
Keeping machines running smoothly is at the heart of every industrial operation. Machine monitoring helps avoid downtime scenarios by providing real-time insights needed to catch problems early and keep equipment working.
Have you been tasked with an IIoT (industrial internet of things) or digital transformation initiative for your company?
Edge devices can help you get live production data from existing equipment (brownfield systems) to:
  • Improve production visibility
  • Help predict maintenance issues
  • Keep production operating smoothly
Whether you’re integrating legacy systems or enhancing smart machines, edge devices provide the bridge between your equipment and your Industry 4.0 or IIoT initiatives.
Now you can turn your existing equipment into a valuable source of real-time data—without costly overhauls or operational disruptions.
This white paper helps you get started. Learn how to add an edge device to a single machine or process, capture critical data, and integrate it into your digital infrastructure.
Read White Paper:
