Monday, October 21, 2019
Horsepower for Impulse Water Turbine
Need to know hp of an impulse water turbine I'm making.
By Hector Lopez on 13 October, 2018 - 1:08 pm
I'm building a water impulse turbine. The tubine is 10 inches in daimeter, receives 100 psi water flow and moves a shaft at 1600 rpm. I want to know how many horse power it may produce.
My email is: hemalo75@yahoo.com
From an old fluid mechanics text:
Power =Flow * Density * (Jet Vel-BladeTip Vel) [1-Cos(BladeTip Angle)]
you have to use consistent units.
By Hector Lopez on 24 October, 2018 - 8:51 pm
All I want to know are the elements I have to take into consideration to calculate hp in a water impulse turbine. Something like: water flow by xxx by bba equal to hp.
Thanks a lot.
hemalo75@yahoo.com
hemalo,
You'll have to test it. It is the same for calculating pump horse power.
So if you have a 2 HP pump delvering 100 psi at your flow, that will be close to what you get in your set up,
good luck
Okay,
From an old Crane Fluid Flow Handbook,
Brake Horse Power(BHP)= GPM*PSI/(1714*Turbine Efficiency).
Beyond that, you have to go into the detail design, and you'll have to talk to a design engineer and design staff.
