T
I tried to install Speedtronic MK V software on a PC Pentium 3 (or P2), why won't the software run? When I install and run the software, I always get the message "Unable to read global section". Does anyone have a solution for me?
Thank you very much.
File Startup log as follow:
This is IDP0043, version 4.3 of the <I> PRODUCT CODE.
IDOS is not currently running!
IDOS Print Spooler is now installed.
DOS Print Queue is Empty.
IDOS Extended Print Queue is Empty.
IDOS-PENTIUM Ver. 3.0, Built on 11/04/94 at 10:32:21
Floating point co-processor is present.
Copyright (C) 1992, 1993, 1994, GE Drive Systems, Salem, Virginia USA
Calibrating IDOS IDLE TIME base parameters (5.4 sec).
IDOS/486 is now running!
** TASK INFORMATION **
Task Name: "Print/MODBUS Dvr" Task Priority: 10 Initial Task State: COM
Initial Task Registers:
EAX = 00000000 EBX = 00000000 ECX = 000000FF EDX = 00001C62
ESI = 00001C7F EDI = 00001000 EBP = 0000091C ESP = 00000FF0
CS:EIP = 00A8:00001CEA DS = 00A0 ES = 00A0 SS = 0F68 FS = 0000 GS = 0000
DOS SEG IDOS SEG SEGMENT TYPE DESCRIPTOR IDOS ADDRESS RANGE
0000 00A0 DATA 00009219-D000CCFF 0019D000 - 001A9CFF
0CD0 ---- 00000000-00000000 00000000 - 00000000
0CE8 00A8 CODE 00009A1A-9D00208F 001A9D00 - 001ABD8F
0EF1 ---- 00000000-00000000 00000000 - 00000000
107A ---- CODE 00000000-00000000 00000000 - 00000000
1369 00B0 0000921A-BD90014F 001ABD90 - 001ABEDF
137E ---- CODE 00000000-00000000 00000000 - 00000000
15F5 ---- CODE 00000000-00000000 00000000 - 00000000
1634 ---- 00000000-00000000 00000000 - 00000000
_sys_load_task: WARNING - ES points before program image. Setting ES to NULL
_sys_load_task: GLOBAL SECTION already exists, but
program segment size differs from GLOBAL SECTION size.
_sys_load_task: Specified GLOBAL SECTION does not exist.
Note: Ethernet Driver not starting. No ETHERNET Configuration File.
Unable to create global section. Status = 0xFFFE
...Unable to create global code section, status = 0xFFFE
Task Name: "BEACON " Task Priority: 9 Initial Task State: COM
EAX = 0000FF26 EBX = 00000000 ECX = 000003EA EDX = 0000FC46
ESI = 0000FF48 EDI = 00000352 EBP = 0000FF68 ESP = 000017F0
CS:EIP = 0004:000002EF DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1A-C000322F 001AC000 - 001AF22F
0323 ---- CODE 00000000-00000000 00000000 - 00000000
0612 ---- CODE 00000000-00000000 00000000 - 00000000
0889 ---- CODE 00000000-00000000 00000000 - 00000000
08C8 000C DATA 0000921A-F23017FF 001AF230 - 001B0A2F
Task Name: "CMDSND " Task Priority: 6 Initial Task State: COM
EAX = 0000FF78 EBX = 00000000 ECX = 000006AA EDX = 0000FB9E
ESI = 0000FF9A EDI = 000004CE EBP = 0000FFBA ESP = 000022F0
CS:EIP = 0004:00000D93 DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1B-100054CF 001B1000 - 001B64CF
054D ---- CODE 00000000-00000000 00000000 - 00000000
083C ---- CODE 00000000-00000000 00000000 - 00000000
0AB3 ---- CODE 00000000-00000000 00000000 - 00000000
0B10 000C DATA 0000921B-64D022FF 001B64D0 - 001B87CF
Task Name: "UDMHDR " Task Priority: 9 Initial Task State: COM
EAX = 0000FF78 EBX = 00000000 ECX = 000006BA EDX = 0000FB9E
ESI = 0000FF9A EDI = 000004C9 EBP = 0000FFBA ESP = 00008D90
CS:EIP = 0004:0000220F DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1B-9000667F 001B9000 - 001BF67F
0668 ---- CODE 00000000-00000000 00000000 - 00000000
0957 ---- CODE 00000000-00000000 00000000 - 00000000
0BCE ---- CODE 00000000-00000000 00000000 - 00000000
0C2B 000C DATA 0000921B-F6808D9F 001BF680 - 001C841F
Note: HOLD LIST is not starting, "HOLD_LIST = Yes" option not found.
Task Name: "ALMLOG " Task Priority: 5 Initial Task State: COM
EAX = 0000FFA8 EBX = 00000000 ECX = 000004EA EDX = 000006FA
ESI = 0000FFCA EDI = 000002EB EBP = 0000FFEA ESP = 00008B90
CS:EIP = 0004:00000BCB DS = 000C ES = 0000 SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1C-9000456F 001C9000 - 001CD56F
0457 ---- CODE 00000000-00000000 00000000 - 00000000
0746 ---- CODE 00000000-00000000 00000000 - 00000000
09BD ---- CODE 00000000-00000000 00000000 - 00000000
0A1A 000C DATA 0000921C-D5708B9F 001CD570 - 001D610F
Note: EVENTRCV is not starting, "EVENT = YES" option not found.
Note: D_IN_RCV is not starting, "SOE = YES" option not found.
Note: CHNGRCV is not starting, "ANALOG_CHANGE = YES" option not found.
Note: EPALOG is not starting, "EPA_LOG = YES" option not found.
Unable to access system global section. MODBUS support is not being loaded.
Task Name: "MODBUS server " Task Priority: 5 Initial Task State: COM
EAX = 0000FF26 EBX = 00000000 ECX = 000008AA EDX = 0000FC46
ESI = 0000FF4F EDI = 00000526 EBP = 0000FF68 ESP = 00003380
CS:EIP = 0004:00001A5E DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1D-70005B2F 001D7000 - 001DCB2F
05B3 ---- CODE 00000000-00000000 00000000 - 00000000
08A2 ---- CODE 00000000-00000000 00000000 - 00000000
0B19 ---- CODE 00000000-00000000 00000000 - 00000000
0B76 000C DATA 0000921D-CB30338F 001DCB30 - 001DFEBF
Note: SR_A is not starting, "SMART_REMOTE = YES" option not found.
Note: SR_B is not starting, "SMART_REMOTE = YES" option not found.
Note: HSERVER is not starting, "HISTORIAN = VAX" option not found.
Note: PLC is not starting, "PLC = YES" option not found.
Note: JEMMETER is not starting, "JEMMETER = YES" option not found.
Note: IMG_HPDJ is not starting, no HPDESKJET to write to.
Note: IMG_HPPJ is not starting, no HPPAINTJET to write to.
Note: IMG_HPLJ is not starting, no HPLASERJET to write to.
Task Name: "IMG_DOTMATRIX " Task Priority: 4 Initial Task State: COM
EAX = 0000FF52 EBX = 00000000 ECX = 0000031C EDX = 000004B4
ESI = 0000FF7B EDI = 000002D2 EBP = 0000FF94 ESP = 00004C60
CS:EIP = 0004:000005F6 DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1E-0000179F 001E0000 - 001E179F
017A ---- CODE 00000000-00000000 00000000 - 00000000
0469 ---- CODE 00000000-00000000 00000000 - 00000000
06E0 ---- CODE 00000000-00000000 00000000 - 00000000
071F 000C DATA 0000921E-17A04C6F 001E17A0 - 001E640F
Unable to map to system global section. Is system running?
Task Name: "STTREND " Task Priority: 5 Initial Task State: COM
EAX = 0000FF26 EBX = 00000000 ECX = 00000BEA EDX = 0000FC46
ESI = 0000FF49 EDI = 00000A2A EBP = 0000FF68 ESP = 00002650
CS:EIP = 0004:00000996 DS = 000C ES = 000C SS = 000C FS = 0000 GS = 0000
0000 0004 CODE 00009A1E-7000465F 001E7000 - 001EB65F
0466 ---- CODE 00000000-00000000 00000000 - 00000000
0755 ---- CODE 00000000-00000000 00000000 - 00000000
09CC ---- CODE 00000000-00000000 00000000 - 00000000
0A29 000C DATA 0000921E-B660265F 001EB660 - 001EDCBF
Note: PL_ADMIN is not starting, "P_LOG = YES" option not found.
Note: PL_PRINT is not starting, "P_LOG = YES" option not found.
IDOS current version: IDOS-PENTIUM Ver. 3.0, Built on 11/04/94 at 10:32:21
Maximum Linear Address = 00100000 Next Available Linear Address = 001EE000
TID ---Task Name---- STATE PRIORITY EVENT FLAGS WAIT MASK
24 STTREND.xsinit HIB 5 00000000 00000000
25 IMG_DOTMATRIX LEF 4 00000000 00000001
26 MODBUS.global HIB 5 00000000 00000000
27 ALMLOG LEF 5 00000000 0000003E
28 UDMHDR.xsinit HIB 9 00000000 00000000
29 CMDSND.xsinit HIB 6 00000000 00000000
30 BEACON.NO SEC HIB 9 00000001 00000000
31 Print/MODBUS Dvr LEF 10 00000000 B001E00C
32 DOS V8086 TASK CUR 4 00000000 00000000
33 IDOS IDLE TASK COM -1 00000000 00000000
