from the Forum department...
Difference between drain and vent
Engineering and workplace issues. topic
Posted by Saeid on 13 July, 2009 - 3:11 pm
I am working on an oil project and I am preparing some datasheets. I want to know differences beween vent and drain (if any) in instruments such as gauges?
Kind answers is appreciated.
Posted by Oliver77 on 13 July, 2009 - 9:56 pm
Well, you vent trapped air/gases and you drain trapped liquids (depending on applications).
For example consider dP transmitter/gages--
for liquid applications, there is a vent screw/hole somewhere in the sensor body that may be used to release the trapped air/gases at the diaphragms of the sensor.
For gas applications, there is a drain screw/hole somewhere in the sensor body that may be used to release the trapped liquids/condensates at the diaphragm of the sensor.
Why do you want to vent and/or drain? Because the trapped gases or liquids may introduce errors in the sensor readings.
Posted by Allan Evans on 14 July, 2009 - 12:23 am
Vent goes up.
Drain goes down
Posted by sushant chanana on 14 July, 2009 - 7:17 am
HI,
Vent is generally for removal of air bubbles & Non condensable gases & drain to remove condensates like in pneumatic air.
Sushant Chanana
Posted by Saeid on 14 July, 2009 - 12:21 pm
Hi
Thanks for your very useful information.
Technological progress has merely provided us with more efficient means
for going backwards.
-- Aldous Huxley
Advertise here
Advertisement
our advertisers
