How we check vortex flow meter yewflo give a correct out put 4-20 against gas flow in side the vortex
If you cannot send the meter out for proper calibration and adjustment, you can do a quick spot check by using another (known/good) flow meter to compare it against and then simply rescale the output.
I've done this for customers in the past with a clamp-on flow meter to test against.
Not 100% perfect, but it works!
