i work in a PTA(Purified Terephthalic Acid for polyester) plant. we are using Nucleonic Level gauges for our Level measurement Requirement for our critical applications eg. reactor,crystalliser etc.. The temp. in most cases is under 250degC and the pressure under 25 bar. we are using berthold level gauges with co-60 rod sources and in some cases caesium-137 point sources with scintillation counters. we are facing lot of problems of interference, wrong level indication, saturation of level indication etc.. inspite of our best efforts and lot of shielding considerations. since this is a slurry application i would like some help on what other types of level measurement can be used for these application. please help.
