N
I am wiring a panel to help a customer get caught up. they are taking 220vac single phase from a transformer and tying L2 to ground and then using a white wire as neutral to go to a 220vac single phase air conditioner. They are also doing this on a second single phase transformer only using the center tap as 110vac hot. Never seen this before, National electric code states no white or gray neutral on a 220vac single phase circuit. Sounds dangerous to me!
does any one know if this is even legal or code?
because I will not wire it this way!
