work in GE Frame 9 Gas Turbine of which control system is Mark IV. We have 5 Gas Turbines. One of the GT if trip then another GT is tripping whether all GTS are in Base load or Part load. Could anyone tell me what is the problem? and tell me where in Mark IV system i have to check. As i knoww if all GTs are running in Base load if any GT trip then it should not try to increase the load of all other GTS as they are already in Base load. Also If GTs are running in Part load they should behave with Droop control.
Could anyone tell me specifically where to look in control system, load control, droop control or frequency control in the Mark IV system? Also could you a little bit explain about droop control. It will be a great help.
