K
On our Frame 9 Gas Turbine running at base load, one of the compressor beeld valves opened due to its control air tube breaking apart. We closed the manual isolation valve of the bleed valve. Is it safe to run the turbine in this condition? What are the possible dangers? It is difficult to be able to work in the turbine compartment to replace the broken tube due to hot temperature and pressure. Any comments would be helpful.
