Export data from Excel to PLC
H
hamda.farag
i know how we can export data to excel from rslinx.
i would like to know how we can export data from excel to plc? or how i can transfer data from excel to memory registery of plc?
I'm not sure what you are trying to do, but I use DDE (dynamic data exchange) with Excel and AB SLC PLCs. You need RSLinx OEM minimum, and you will have to write some VBA to control the communication. Example: I have one part that has over 1200 different configurations, put in by a waterjet cutter. The operator scans the barcode label into Excel, which matches the p/n to a database, then sends the proper code to the PLC, which controls the cutter. If this sounds like what you want to do contact me below.
ed.mart @ cvgrp. com
To the second (Excel to PLC) you can use JagusDataLogger embedded in a Excel macro.
Contact support @ pdutech. com for more info.
Martin
Brian E Boothe
I'm needing to find out what others use as their Project ID. What's the common format that a lot of people use for their Project ID???
