Dear Member,
Has anyone here had experience with out of range 3051 sensor? We bought 3051 transmitter range 2 (-625 mbar to 625 mbar) with remote capillary seal. it was installed on stripper column with transmitter mounted in the middle between two tapping points. distance between two tapping points is 18 meter, which cause static pressure on the sensor around -1.6 bar. If refer to 1199 capillary calculation manual, 4mA point should be set at this pressure. but since transmitter range only -625 mbar, we could not change the URV down to -1.6 kPa. Is there any solution beside change the sensor to higher range?
appreciate if any of you have solution for this kind of issue.
thanks.
thanks.
