F
Hello all... I need all expert here
We get turbine trip with unclear cause.... Below SOE. What the possible cause of trip?<pre>
Site: Aramco Hawiyyah
Unit: T1
Data Types: Process Alarms, Events, SOE's
Time Type: Local Time
Start Time: 2014.10.16 07:40:55.000
End Time: 2014.10.16 15:40:55.000
Report: Exception
Time Unit S P Drop/Point Typ Description
16-OCT-2014 08:36:51.725 T1 1 L26BAH SOE Turbine Compartment Temp High
16-OCT-2014 08:36:51.808 T1 0 L26BAH SOE Turbine Compartment Temp High
16-OCT-2014 08:36:51.828 T1 1 L26BAH SOE Turbine Compartment Temp High
16-OCT-2014 08:36:52.107 T1 0 L26BAH SOE Turbine Compartment Temp High
16-OCT-2014 08:36:52.226 T1 1 L26BAH SOE Turbine Compartment Temp High
16-OCT-2014 12:39:38.418 T1 1 XS_9460B1 SOE DCS CGT-1001 cabinet air flow switch 1
16-OCT-2014 12:39:38.418 T1 1 XS_9460B2 SOE DCS CGT-1001 cabinet air flow switch 2
16-OCT-2014 12:39:38.418 T1 1 XS_9460C SOE DCS CGT-1001 cabinet air temperature switch
16-OCT-2014 12:39:38.418 T1 1 XS_9460D1 SOE DCS CGT-1001 cabinet power supply
16-OCT-2014 12:39:38.418 T1 0 LSH_1201 SOE FUEL GAS FILTER-COALESCER UPSTREAM LEVEL
16-OCT-2014 12:39:38.418 T1 0 LSH_1203 SOE FG FILTER DOWNSTREAM LEVEL HIGH
16-OCT-2014 12:39:38.418 T1 0 LSH_1205 SOE FUEL GAS FILTER-COALESCER D-1001 - UPS
16-OCT-2014 12:40:01.519 T1 1 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 12:40:01.519 T1 0 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 12:52:00.917 T1 1 HS_1151_C SOE LO HEATER DH-1004A - MANUAL START/ STOP AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1152_2A SOE LO PUMP MANUAL STOP AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1152_2B SOE LO PUMP MANUAL STOP AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1152_C SOE LUBE OIL SKID - PUMP A/B AUTO SELECTED AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1157 SOE COOLER FAN - MANUAL START/ STOP AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1158 SOE COOLER FAN - MANUAL START/ STOP AT LGP
16-OCT-2014 12:52:00.917 T1 1 HS_1157_C SOE COOLER FAN - AUTO SELECTED AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1151_C SOE LO HEATER DH-1004A - MANUAL START/ STOP AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1152_2A SOE LO PUMP MANUAL STOP AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1152_2B SOE LO PUMP MANUAL STOP AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1152_C SOE LUBE OIL SKID - PUMP A/B AUTO SELECTED AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1157 SOE COOLER FAN - MANUAL START/ STOP AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1158 SOE COOLER FAN - MANUAL START/ STOP AT LGP
16-OCT-2014 13:10:58.843 T1 1 HS_1157_C SOE COOLER FAN - AUTO SELECTED AT LGP
16-OCT-2014 13:53:42.404 T1 1 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 13:53:42.404 T1 0 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 13:53:42.405 T1 1 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 13:53:42.405 T1 0 Q 0000 ALM ALARM XMIT SUSPENDED. CPU SWITCHED.
16-OCT-2014 13:53:48.081 T1 1 Q 0698 ALM <R> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0699 ALM <R> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0700 ALM <S> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0701 ALM <S> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0702 ALM <T> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0703 ALM <T> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0713 ALM <R> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0714 ALM <R> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0716 ALM <S> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0717 ALM <S> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0719 ALM <T> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:48.081 T1 1 Q 0720 ALM <T> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0698 ALM <R> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0699 ALM <R> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0700 ALM <S> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0701 ALM <S> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0702 ALM <T> SLOT 7 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0703 ALM <T> SLOT 12 VSVO DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0713 ALM <R> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0714 ALM <R> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0716 ALM <S> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0717 ALM <S> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0719 ALM <T> SLOT 5 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:53:52.203 T1 1 Q 0720 ALM <T> SLOT 15 VVIB DIAGNOSTIC ALARM
16-OCT-2014 13:54:26.873 T1 1 Q 0379 ALM T1\L96VDC_R_ALM
16-OCT-2014 13:54:26.873 T1 1 Q 0380 ALM T1\L96VDC_S_ALM
16-OCT-2014 13:54:26.873 T1 1 Q 0381 ALM T1\L96VDC_T_ALM
16-OCT-2014 13:54:26.873 T1 1 Q 0382 ALM T1\L96VDCNEGALM
16-OCT-2014 13:54:26.883 T1 1 Q 0010 ALM FUEL GAS SUPPLY - BLOW DOWN - AOV VALVE OPEN
16-OCT-2014 13:54:26.883 T1 1 Q 0088 ALM GT COMPARTMENT TEMP HIGH (26BA)
16-OCT-2014 13:54:26.883 T1 1 Q 0131 ALM TURBINE LUBE OIL TANK TEMPERATURE LOW (LT-OT-1A)
16-OCT-2014 13:54:26.883 T1 1 Q 0138 ALM TURBINE LO EMERG.PUMP UNDERVOLTAGE
16-OCT-2014 13:54:26.883 T1 1 Q 0141 ALM <R>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0142 ALM <S>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0143 ALM <T>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0154 ALM FORCED SIGNAL DETECTED ALARM
16-OCT-2014 13:54:26.883 T1 1 Q 0166 ALM OVERTEMPERATURE ALARM
16-OCT-2014 13:54:26.883 T1 1 Q 0167 ALM WHEELSPACE TEMP DIFFERENTIAL HIGH
16-OCT-2014 13:54:26.883 T1 1 Q 0240 ALM FIRE DETEC SYS TROUBLE TURB/ACCESS AREA
16-OCT-2014 13:54:26.883 T1 1 Q 0277 ALM MASTER PROTECTIVE TRIP (MK6-PB/CCR-XS-1032-B)
16-OCT-2014 13:54:26.883 T1 1 Q 0278 ALM Turbine EMERG MANUAL TRIP SIGNAL FO
16-OCT-2014 13:54:26.883 T1 1 Q 0280 ALM 4 RELAY CIRCUIT STATUS - ESTOP PB - INVERSE FO
16-OCT-2014 13:54:26.883 T1 1 Q 0321 ALM N28VDC TTPW BUS GROUND
16-OCT-2014 13:54:26.883 T1 1 Q 0322 ALM P28 VDC TTPW BUS GROUND
16-OCT-2014 13:54:26.883 T1 1 Q 0366 ALM OVERTEMPERATURE TRIP
16-OCT-2014 13:54:26.883 T1 1 Q 0367 ALM EXHAUST OVERTEMPERATURE TRIP FO
16-OCT-2014 13:54:26.883 T1 1 Q 0379 ALM T1\L96VDC_R_ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0380 ALM T1\L96VDC_S_ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0381 ALM T1\L96VDC_T_ALM
16-OCT-2014 13:54:26.883 T1 1 Q 0382 ALM T1\L96VDCNEGALM
16-OCT-2014 13:54:26.883 T1 1 Q 0400 ALM Skid LO filter diff PRESS HIGH ALARM (PDSH-1159)
16-OCT-2014 13:54:26.883 T1 1 Q 0409 ALM F. GAS FILTER-COALES. DWNSTRM LEVEL HIHI (LS-1204)
16-OCT-2014 13:54:26.883 T1 1 Q 0432 ALM PROCESS SPEED/LOAD SETPOINT FAULT
16-OCT-2014 13:54:26.883 T1 1 Q 0440 ALM VMS COMMON FAULT
16-OCT-2014 13:54:26.883 T1 1 Q 0547 ALM RACK-1 SLOT-7 MODULE Not OK
16-OCT-2014 13:54:26.883 T1 1 Q 0551 ALM H01-XVE-1017 Gearbox Not OK
16-OCT-2014 13:54:26.883 T1 1 Q 0576 ALM CHANNEL 3 Not OK
16-OCT-2014 13:54:26.883 T1 1 Q 0580 ALM CHANNEL 3 Not OK
16-OCT-2014 13:54:26.883 T1 1 Q 0584 ALM FUEL GAS SUPPLY ISOLATION VALVE - SSV OPEN
16-OCT-2014 13:54:26.883 T1 1 Q 0585 ALM PUMP/GEAR LUBE OIL TANK TEMP HIGH
16-OCT-2014 13:54:26.883 T1 1 Q 0648 ALM PUMP/GEAR LUBE OIL COOLER FAN A DISABLED
16-OCT-2014 13:54:26.883 T1 1 Q 0649 ALM PUMP/GEAR LUBE OIL COOLER FAN B DISABLED
16-OCT-2014 13:54:26.883 T1 1 L4MOV_002 EVT Pump Discharge MOV MOV-1002,Motor ESD Command
16-OCT-2014 13:54:26.885 T1 1 Q 0010 ALM FUEL GAS SUPPLY - BLOW DOWN - AOV VALVE OPEN
16-OCT-2014 13:54:26.885 T1 1 Q 0088 ALM GT COMPARTMENT TEMP HIGH (26BA)
16-OCT-2014 13:54:26.885 T1 1 Q 0131 ALM TURBINE LUBE OIL TANK TEMPERATURE LOW (LT-OT-1A)
16-OCT-2014 13:54:26.885 T1 1 Q 0138 ALM TURBINE LO EMERG.PUMP UNDERVOLTAGE
16-OCT-2014 13:54:26.885 T1 1 Q 0141 ALM <R>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0142 ALM <S>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0143 ALM <T>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0154 ALM FORCED SIGNAL DETECTED ALARM
16-OCT-2014 13:54:26.885 T1 1 Q 0166 ALM OVERTEMPERATURE ALARM
16-OCT-2014 13:54:26.885 T1 1 Q 0167 ALM WHEELSPACE TEMP DIFFERENTIAL HIGH
16-OCT-2014 13:54:26.885 T1 1 Q 0240 ALM FIRE DETEC SYS TROUBLE TURB/ACCESS AREA
16-OCT-2014 13:54:26.885 T1 1 Q 0277 ALM MASTER PROTECTIVE TRIP (MK6-PB/CCR-XS-1032-B)
16-OCT-2014 13:54:26.885 T1 1 Q 0278 ALM Turbine EMERG MANUAL TRIP SIGNAL FO
16-OCT-2014 13:54:26.885 T1 1 Q 0280 ALM 4 RELAY CIRCUIT STATUS - ESTOP PB - INVERSE FO
16-OCT-2014 13:54:26.885 T1 1 Q 0321 ALM N28VDC TTPW BUS GROUND
16-OCT-2014 13:54:26.885 T1 1 Q 0322 ALM P28 VDC TTPW BUS GROUND
16-OCT-2014 13:54:26.885 T1 1 Q 0366 ALM OVERTEMPERATURE TRIP
16-OCT-2014 13:54:26.885 T1 1 Q 0367 ALM EXHAUST OVERTEMPERATURE TRIP FO
16-OCT-2014 13:54:26.885 T1 1 Q 0379 ALM T1\L96VDC_R_ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0380 ALM T1\L96VDC_S_ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0381 ALM T1\L96VDC_T_ALM
16-OCT-2014 13:54:26.885 T1 1 Q 0382 ALM T1\L96VDCNEGALM
16-OCT-2014 13:54:26.885 T1 1 Q 0400 ALM Skid LO filter diff PRESS HIGH ALARM (PDSH-1159)
16-OCT-2014 13:54:26.885 T1 1 Q 0409 ALM F. GAS FILTER-COALES. DWNSTRM LEVEL HIHI (LS-1204)
16-OCT-2014 13:54:26.885 T1 1 Q 0432 ALM PROCESS SPEED/LOAD SETPOINT FAULT
16-OCT-2014 13:54:26.885 T1 1 Q 0440 ALM VMS COMMON FAULT
16-OCT-2014 13:54:26.885 T1 1 Q 0547 ALM RACK-1 SLOT-7 MODULE Not OK
16-OCT-2014 13:54:26.885 T1 1 Q 0551 ALM H01-XVE-1017 Gearbox Not OK
16-OCT-2014 13:54:26.885 T1 1 Q 0576 ALM CHANNEL 3 Not OK
16-OCT-2014 13:54:26.885 T1 1 Q 0580 ALM CHANNEL 3 Not OK
16-OCT-2014 13:54:26.885 T1 1 Q 0584 ALM FUEL GAS SUPPLY ISOLATION VALVE - SSV OPEN
16-OCT-2014 13:54:26.885 T1 1 Q 0585 ALM PUMP/GEAR LUBE OIL TANK TEMP HIGH
16-OCT-2014 13:54:26.885 T1 1 Q 0648 ALM PUMP/GEAR LUBE OIL COOLER FAN A DISABLED
16-OCT-2014 13:54:26.885 T1 1 Q 0649 ALM PUMP/GEAR LUBE OIL COOLER FAN B DISABLED
16-OCT-2014 13:54:26.885 T1 1 L4MOV_002 EVT Pump Discharge MOV MOV-1002,Motor ESD Command
16-OCT-2014 13:54:26.920 T1 1 Q 0010 ALM FUEL GAS SUPPLY - BLOW DOWN - AOV VALVE OPEN
16-OCT-2014 13:54:26.920 T1 1 Q 0088 ALM GT COMPARTMENT TEMP HIGH (26BA)
16-OCT-2014 13:54:26.920 T1 1 Q 0138 ALM TURBINE LO EMERG.PUMP UNDERVOLTAGE
16-OCT-2014 13:54:26.920 T1 1 Q 0141 ALM <R>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.920 T1 1 Q 0142 ALM <S>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.920 T1 1 Q 0143 ALM <T>CORE P28V PWR SUP. OUT OF LIMITS - ALM
16-OCT-2014 13:54:26.920 T1 1 Q 0154 ALM FORCED SIGNAL DETECTED ALARM
16-OCT-2014 13:54:26.920 T1 1 Q 0166 ALM OVERTEMPERATURE ALARM
16-OCT-2014 13:54:26.920 T1 1 Q 0167 ALM WHEELSPACE TEMP DIFFERENTIAL HIGH
16-OCT-2014 13:54:26.920 T1 1 Q 0240 ALM FIRE DETEC SYS TROUBLE TURB/ACCESS AREA
16-OCT-2014 13:54:26.920 T1 1 Q 0277 ALM MASTER PROTECTIVE TRIP (MK6-PB/CCR-XS-1032-B)
1</pre>
Unit: T1
Report: Exception
1</pre>
