Hello dear experts, I bring you a question about a MS6001B with TMR control, available with diesel and gas ignition.
This gas turbine was originally purchased with only diesel firing, and the modification for gas firing was done a few years later (by GE obviously).
The question is, every time the turbine starts with gas ignition, diesel forwarding pump 88FD1 also starts, the same for L20CF1X solenoid which is also energized, magnetizing the coupling and making the high pressure pump for diesel move along with the accessory gear drive.
Is this ok, or did GE forget to modify this logic?.
Thanks in advance!
Thanks in advance!
