Hi. I am working on a problem. Liquid foam is filled into metallic tubes (metal width about 1-2mm). However sometimes some space is not properly filled and some air is left inside the tube where foam is not properly filled. I want to detect if there is some space (air) is left inside the tube. What is options I can use to detect the air left inside through the metallic tube? Any guidance please
