Hi Everyone,
I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online. It arrived in the original packaging and had the safety label around the top of the unit, so it seems that it is as advertised and no need to suspect that it would have problems. I purchased secondhand, a power supply to attach to it and program it from the bench instead of in the machine. The customer also provided me with an SD card containing the project file(s) for the machine. I am able to load the project in CX-ONE (running on Win 7) just fine. My computer has a native serial port (COM1) and I built a programming cable to work with the DB9 peripheral port according to a diagram I found online.
The processor powers up right away with the ERR/ALM continuously on. No other LEDs came on initially, and after a bit of playing around with communications settings, I finally landed the right protocol and my computer seemed to identify the processor correctly. I compiled the source and attempted a transfer to the PLC. I got some failed message (or maybe messages) at the end of the transfer. It did seem to send all of the binary code, it just ended with an error message that I unfortunately didn't write down or grab a screenshot.
Anyway, what I have now is a PLC processor with the ERR/ALM LED on always, I've never seen it in RUN mode, and now after the programming attempt, I'm seeing the COMM LED strobing at about a .5sec frequency (with or without a cable attached to the peripheral port), AND I cannot get CX-ONE to again acknowledge the processor anymore. I'd like to reset this back to the way it arrived to me, but can't figure out how to make that happen offline. The DIP switches don't seem to cause that effect. I should say also that the DIP switch settings are all OFF except 3 and 7.
Any help is much appreciated!
Thanks,
John
Thanks,
John
