Hello all,
I have two Bridgeport Interact II vertical mills. We have been running linuxcnc on the newer (1994) machine for almost two years. I am in the process of retrofitting the second (older) of the two. The spindle motor was working fine when the TNC controller finally quit on this machine. The CONTROL TECHNIQUES 6P4Q-7.5 spindle drive on this had issues when it got hot so I want to replace it.
My question for this forum is this: Can you help me decide whether I should purchase a (used) DC speed controller and keep the existing spindle motor (specs below) or should I rip it all out and put a 3ph motor and a VFD in it? I am perfectly comfortable with the 3ph/AC motors and controls, DC motor controls, not so much.
Parker 514C-32-00-00-00 controllers are available for $700-$900 on ebay. Can anyone help me determine if this Parker controller will work with my spindle motor?
Is there a better fit?
Thanks in advance!
The manual for my 6P4Q-7.5 drive describes my spindle motor as follows:
Thanks in advance!
Code:
Motor type 2M112L
RATING IN CONJUNCTION WITH 6P4Q-7.5 DRIVE MODULE
0KW at Orpm
8KW at. 1000RPM
6KW at 4000RPM
4KW at 6000RPM
ARMATURE
Voltage - 400V
Current - 0/27/18.5/14A
FIELD
Voltage - 150V
Current - 3.8/0.78/0.48A
MOUNTING
Special flange
EXTRAS
Two microthermal sensors embedded in the windings
VENTILATION
Separate three-phase motor-driven fan unit with air filter mounting on main motor frame
Voltage - 380/415V
Current - 0.7A
TACHOGENERATOR
Direct coupled to main motor armature spindle. 20V/1000 rpm
