We have three pumps of different capacities driven by VFDs. A PLC chooses which pump to run based a flow rate. The VFD for the selected pump gets a signal from the PLC based on output pressure. This is for a small domestic water system which includes fire hydrants. We are worried that any failure in the PLC system would require our operators to manually regulate pressure 24/7 until the system could be repaired. We decided to look into a PID controller that could be wired from the main pressure sensor directly to the VFD speed input for the mid-sized pump. But when I started looking into it I saw references to using a VFD as a PID. Is it realistic to think we could simply connect the pressure sensor directly to the VFD? We have MGI inverters with Mitsubishi controls.
