We use Honeywell Experion PKS and I setup multiple displays that our operators use depending on which system within our facility they are tasked with monitoring. We also have Modicon PLCs that we feed into the Honeywell system by creating points within Point Builder that have the Modicon PLC as the source address.
In this example, we have a prox sensor mapped to a coil in our Modicon PLC that triggers every time the sensor sees a tooth on a sprocket. This triggers approximately every 0.8sec. When I map that coil to a point in Point Builder, then map that point to a visual indicator on one of the displays that should blink red every time the coil in the PLC triggers. Well as I have it setup now, the point seems to be missing a lot of the triggers. It may catch 1 or 2 back-to-back, then maybe wait anywhere from 15-25sec before trigger again, and this sporadically continues. I've tried adjusting the scan time of the point in Point Builder, but that doesn't seem to help. How can I fix this so it continuously catches every trigger?
